How to figure out fuse size (amperage)
Hey guys, I was wondering if someone can tell me what size fuse I need to use, or how I can find out. I want to put 2 fuses between my 2 batteries.
The fuse locations are circled in this crappy drawing I made, lol
![](http://i53.tinypic.com/pbxht.jpg)
Why are you running 2 batteries? That's beyond overkill for just a JL 1000/1. Especially since the slash series amps have internal regulated power supplies. Save yourself the headache, put 1 fuse between the main battery and the amp and call it a day.
Plus is your picture you're running the fuses in the same line, it's not like if 1 blows the other is going to save the circuit.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Are you simply putting the batteries in parallel with each other or using an isolator? If you're just putting them in parallel (from your drawing, this is what you are doing), you should put in the same size fuse on both lines.
As for two batteries, if they were significantly different in age, you may run into issues with one vampiring off the other.
Big Mack
I don't see him cutting between the battery and alt...
Nope. You should put a fuse on the wire that travels between the batteries if you're not using a fuse block. Since you are, that's all the fusing you need.
Agreed.
Assuming he's running the amp off the aux battery for the shortest connection possible, he should fuse between that battery and amp with a fuse in the line between the two batteries for protection on that wire.
Big Mack
Agreed.
Big Mack
I know. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Correct. Whichever battery your amp is pulling from, it shouldn't exceed the 100A mark. If it does, you have an issue. In reality, you could pull well over 100A for about 3 seconds before it will start to come unglued, but we're mostly concerned about the dead short issue. That's what fuses are for.
BTW - very smart to ask PRIOR to the wire fire. Good plan.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Big Mack
Big Mack
Big Mack
Big Mack
Raisin
03-14-18 06:20 PM
bagwell
02-15-06 10:45 AM
illimental
12-30-05 12:11 AM
