Battery drain, 2001 rx300
I am having a problem with battery drain, I used the test light and when i pulled out a white fuse marked short, the light went out, I started the vehicle and all is fine except the navigation display is out, I can't find a description on this fuse, no amp marking, just a white fuse, maked short on cover , position is above the 3 spare fuses, any help would be appreciated, Thank you......Tom
mgaja
RX - 1st Gen (1999-2003)
12-11-09 11:59 AM
smokedawgs
04-25-08 10:05 AM
