Need amp suggestions
I've already bought everything but the amp. I have a pioneer 3200bt hu. I have polk mm 5.25 components for the front. They are 200 watts peak and 90 rms each. Polk mm 6.5 2-way in the rear. They are 200 watts peak and 100 rms each. Also one kicker comp 4 ohm 300 watts peak and 150 rms svc 10 inch sub. I'm new to the audio game in general and have around 250-300 to spend on a amp to power this system. I've been doing some reading on the forums before posting this and I'm guessing a 5 channel amp would be got to run this right? If not what would be some good options to run. Any and all suggestions welcomed. Thanks in advance.
Zombie Slayer
Not a bad amp. Soundstream used to be the ISH!!!! back in the day. Their quality fell for a while but they appear to have their ish back together now. Personally I have had good results from their tarantula line of amps. So, I would think the rubicon line should be ok. Can't comment on the price though.
Mack.....Thoughts???
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
One thing I'd be concerned with is why if "premier electronics" is an authorized dealer the warranty is through them. They state at the top it's a manufacturer's warranty, but in the auction it states differently. I'd be leery about that.
If that amp can live up to the specs, and I think it can because they are not outrageous, I'd say it's a good candidate if you want to go the all in one route. In your case, I don't see that being a bad choice. If you were considering any additional upgrades, however, a dedicated power supply for each is essential, IMO, for top performance.
As korsu said, not commenting on price.
Big Mack
Thanks. I picked one up off of another site for about 40 bucks cheaper. I'll comment on it once I get everything hooked up. I think it should be good cause I have no plans for anything more. I'm not much of a audio person just wanted something better than stock after listening to my mom new tsx stock system. Even her stock speakers made mine sound like crap imo. Now I will be happier hopefully.
saelee39
01-09-09 11:35 AM
kietlander
12
11-18-05 04:08 PM
Wald GS
09-22-05 09:24 PM
