first gen RX powered sub install problems w/ fast-9999
could use some expert help here PLEASE
so i bought an amplified bazooka bass tube and tried installing it today. i am using a fast-9999 connector that was included in the kit which wires directly to your factory stereo wire harness with 6 quick connectors. apparently this connection allows you to skip drilling the firewall since the sub draws power form the 12v source in the factory stereo harness. so says the box n directions.
the first problem i ran into was finding a correct wiring diagram for the stereo which i luckily found right here on CL after some searching.
the second is now that it is all connected, wires ran and hidden, i am gettin very little volume out of the sub but it is noticeably audible with the stereo volume **** around 9 or 10 o'clock and is drowned out by the rest of the speakers if turned up any higher.
my concern isnt the ground (i scrapped a small area of primer away in the spare tire compartment and grounded it with a self tapping screw and a large washer.) but i feel like the remote wire that i connected to the corresponding fast connect isnt the correct/best one to use. it is the A1 slot for accessories "ACC GRY/RED" wire.
Im wondering if there is a better spot to connect the remote wire for the amp'd sub since the antenna is useless being that it is down in CD and Tape modes. Its late and i dont feel like pulling the dash out again until morning so hopefully one of u west coast guys will see this and have an answer for me in the morning. it would be great just to here some useful ideas
wiring diagram i used and found here on CL is right here...
What an absolutely horrible idea. Considering the factory wiring is only intended to run the factory unit, it SHOULD NOT be used to power an external amplifier. You are choking the amp, and will likely pop the fuse very soon by using this. You need to put in a dedicated power line for the sub, regardless of what those tools at Bazooka say. Even at 100% efficiency, a 100 watt amp (assuming you did not buy the 200 watt one that it specifically says do not use it for) draws a tad over 8 amps. This, combined with the radio, is going to blow the fuse, since most are rated for 10 - 15 at the most.
There are very few shortcuts that work well in audio, so take your time, put in a power cable, and only use that connector for getting the signal.
PS - it's not the remote signal you have an issue with. The one you tapped should be the correct one. If it's coming on, and stays on through the use of CD, it's right.
Big Mack
Big Mack
Lowrider25
04-30-18 07:54 AM
paintrain
RX - 1st Gen (1999-2003)
08-03-11 06:27 PM
