adding aux, need some help
first off i own a 96 sc400 stock HU w/ cd changer
the cd changer is gone but the connectors are still there.
with the cd changer not installed i cant even select the input for it.
all i need to know is if i can jump the connector from the stock cd changer or from behind the HU to make the HU believe the cd changer input is there. i only want to use it for basically a blank station so i can use the aux cable im installing.
if anyone can help i would appreciate it. diagrams or pinouts with wire colors would be very helpful too
the aux cable will be installed using the test servo cable method\
if anyone can tell me which connector is to what and the pin numbers and what they are for i could probably figure the wiring out myself
elhalisf
01-20-04 09:28 PM
