SC400 Electrical Gremlin- taillamp warning light stays on
hey everyone
the check taillamp light on my SC400 is playing tricks with me![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
When I start the car, no warning lights light up, but as I'm driving the light that tells me to check my tail lamps comes on until I turn off the car and restart it a bit later
I've checked all the bulbs all light up nice and bright and the harnesses and everything seem to be working fine
anyone have some ideas on what I can do to fix this problem?
thanks!
thanks!
nope!! thats what I dont get... havent messed with anything- and it doesnt just stay on it turns on sometimes while driving then when i start the car the next time it stays off...
its like it develops a bad connection or something randomly and every time I check... everything is fine haha
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
oh well I'll swap some bulbs around see what happens
damn cars these days... hehehe tell you have a problem before ya have a problem![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
thanks
if that doesnt work are there any other ideas?
thanks
Possibly, a bulb, or the 3rd brake light element, is causing reduced amps, or to much: the KEY is - what triggers the computer to issue the error?
Again, is to little or to much amperage the trigger?
Mike
sc400
agi@pclv.com
ps - related issue is involved ( spioler brake -light works with 12v, but is not receiving V when pedel is correctly triggering the left/right brake lights. - NO ERROR lights....
Mike
sc400
agi@pclv.com
Does it come on only after you depress the brake pedal? Or after driving and hitting the brake pedal a few times? Sometimes it works to just replace ALL the tail lights/brake lights. Good luck.
