future setup
planning to run a JL audio 12w1 with sealed box and a JX250 amp. anyone running just a single sub in their sc? can you hear it in the car and outside the car? i want bass but not too much. any help would be appreciated.
i guess no one is running a single sub in the trunk of their SC? come on i know someone on here is? how is it? can you hear it from the inside of your car? does it bump?
Zombie Slayer
A lot of us do. A ton use the factory location and use an upgraded 10" or 12" that is well suited to Infinite baffle setups.
Others, like myself, have enclosures in the trunk. Currently, (since I am mid build of a new system) have a simple and cheesy Sony Xplode being powered by the PHENOMENAL older Orion 2150SX. 600w RMS at 4 ohms. Bumps well with gains turned way down. Loud but not obnoxious (unless I want it to be). Sealed enclosure. Roughly 1.5 cubic feet
You will be fine with an enclosure in the trunk. Just be sure to remove the factory sub first.
JonSC4
12
09-18-08 07:53 AM
Rock-a-Lex
02-22-08 07:57 AM
