IS the JL XD300\1 worth the $100 premium over the JL JX250\1?
Zombie Slayer
The IB410 Only likes 100w RMS. So the JX250/1 is the better choice.
Although There are many other amps that fit the bill for much less.
The Rockford Fosgate R125-2 will give you 125 w @ 4ohms for only $99 retail from RF's site. I'm sure if you search you can find cheaper.
From what I am reading the sub does not handle that kind of power..
Interesting I will take a look at that. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
although is the sub 8 ohms so its half that?
Zombie Slayer
yeah. The total output of the amp will be halved with the 8 ohm load.
Cadence has a monoblock that is 200w @ 4 ohm. Sells for around $110 online. I have used cadence in the past and I found them to be a nice cost effective solution.
Zombie Slayer
Nope! I personally do not believe in Capacitors at all. They are just band-aids. Anyway, with the amp you are running you should be in no danger of hitting the limits of the alternator.
Okay so the amp will be at my place today. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Will the built in High Level OEM Integration Input that is built into the amp work fine or should I invest in a separate unit like this unit..
Audiocontrol LC2i.
http://www.audiocontrol.com/t34/1761...l----LC2i.html
Thanks guys!
Audiocontrol LC2i.
Thanks guys!
Pineapple
08-11-07 01:32 PM
infa_red
05-04-07 08:13 AM
cliffud
06-16-06 04:49 PM
jtgs400
06-16-06 01:32 AM
