tone & probe vs multimeter
I've never used a tone and probe. But I wonder if it's better then using a multimeter?
For example, if I am attempting to locate which wire is my turnsignal wire and I don't want to poke holes in a bunch of wires till I find the right one wouldn't a tone and probe be better?
Can a tone and probe be used the same way a multimeter is used?
I guess I am not sure of the difference between them other then I know multimeter doesn't send tone.
Zombie Slayer
Can you explain what a "tone and probe" is?
But aside from that there is no better tool for testing leads than a multimeter. The extremely high resistance in a MM helps prevent very expense computers from going boom when probing wires!
never used a tone and probe but i swear by fluke multimeter, loads of information. also i just picked up the Power Probe 3 it allows for testing of power and ground circuits as well as tell you voltage at point of testing, and you can supply power and ground to test motors and things of that nature. i havent used it yet but have been thinking about getting it for a while. i also work in a dealership setting so i could justify spending $160 on the power probe ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
also in the industry it is frowned upon to poke holes in wires to test for power. back probing connectors is also iffy on who you talk to u. it is best to keep the circuit in tact and operating condition
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Big Mack
i was taught that in my automotive school, but yes sometimes it is inevetable, they were also showing weather-pak connectors where destroying the insulation can cause condensation to get in and corrode the connector. but in the dealer setting i have been shown and taught to backprobe. like i said depends on who you talk to
maxx430
08-23-12 10:46 PM
