Adding NAV where there wasn't a NAV??
What is involved in adding the NAV to a non-NAV'd '98 LS400? I can't seem to find a definitive answer by searching. The reason I ask is that every now and then, I'll see a used one for sale on e-bay.
the answer is: It probably CAN be done.
the question is how much are you willing to spend for it?
if you can get the oem nav for $200-300 bux, then you may consider retrofit it, you get the the oem nav for more than that, then might as well get the aftermarket nav, you know it works for sure.
you are looking at building connectors and rewire a "bunch" of wires, assuming you have a schematic for them. else, there is NO hope.
Anh
Anh
