SC300 Radio Issue
I thought I'd ask the forum before taking the car in. I have a '92 Lexus SC300 with 86,000 miles.
The radio is OEM with the cassette feature. The radio all of a sudden stopped working.
No light on the radio.
Antenna does not go up (is in down position).
I checked and replaced (just to be sure) the two fuses. One in the engine compartment and the other on the drivers side inside.
In doing Internet searches I have come across a 'radio reset code' but never mentioned in the same breath for a SC300.
Any thoughts or suggestions would be greatly appreciated. Else she goes into a local automotive audio joint.
Thank You
Thank You
If you are confident that the fuses are good and you didn't do anything that compromise the accessory harness, you might want to take a look at the amp to see whether it has gone bad.
trhs75
RX - 1st Gen (1999-2003)
05-30-09 04:30 PM
TroySC300
09-22-07 09:56 PM
