Help! 93 Ls400 sub install
Ok so I have all the wiring done and everything, got it through my firewall, all I need is to connect my amp and sub and I'm good.
One big problem though, the harness for my head unit. http://www.sonicelectronix. com/item_12706_Metra-70-8112.html
That's the harness I used because I have a Nak system and the regular connector doesn't work. As you can see it uses all 4 RCA's spots in back of my head unit. And i need to find a way to connect my 2 extra rca's for my sub/amp in my trunk...
Is there like a rca hub i could connect to my head unit which would allow me to connect all the speakers and sub?
If your deck does change the rear to sub in the menu, I would use the Y connectors to split the front signal between the front/rear input on the harness, use the rear only for the sub, and retain sub control.
Big Mack
It's a jvc kd r520 and I'll be putting two alpine type r's with an alpine digital amp.
If I add a y connector won't I be losing the rear speakers either way, so I may as well just replace the rears with the sub?
Unless I somehow run the rears through my alpine amp?
Big Mack
Did you read your manual or what I wrote? That deck has the option of controlling the subs with a non fading output. If you connect the Y to the front output, you run that to the rear input of the harness, thus retaining the rear speakers through the Nak system (it feeds the front signal to both sets, in other words). The only thing is that you lose fader control, but how often do you just fade the music to the front? If you do that a lot, why do you even want rear speakers operating?
Big Mack
Big Mack
Also thanks for the help ! I was starting to get discouraged.
btw this link should work http://www.sonicelectronix.com/item_...a-70-8112.html
You connect the Y (you will need two 1 male to 2 female Y's) at the back of the deck to the front output. This, essentially, gives you two left and two right outputs from the front channels, and you plug in the R/L from both front and rear inputs on the harness. The rear output from the deck is then hooked up to the RCA going to the sub amp. You will need to turn on the sub out in the menu on the deck, as it defaults to rear (AKA full range).
Big Mack
Glad to help, mang. We all learned somewhere, I'm just passing it along like was given to me.
Big Mack
Big Mack
I'm starting to think this, too. Totally kidding. It's kind of an abstract thought process when you're new to it, but you're close with what you have below.
Switch this to the front being split and you're golden. The reason I say this is because the sub output from your deck, when switched on, is crossed over and can be attenuated by the deck if necessary by going through a couple buttons. If you don't do this, you would then need to get out of the car, turn the gain down on the amp, get back in the car, and repeat. If you have it controllable at the driver's seat, it's always more advantageous, especially when tuning, but that's a bit farther down the rabbit hole than we need to go right now.
Your way will work, but it's definitely not how I would do it.
Big Mack
However I thought of something else that may work. If I use two y connectors. And plug each male into my left and right rears which are also for sub. Hypothetically I should now have a leftr and right for my rear speakers. As well as another 2 for my sub. And then I'll still have the two for the front.
Big Mack
Big Mack
Big Mack
Okay so I got my head unit to work again, 2 of the pins in the harness were in the wrong place so i had to take them out and put them in the right spot. But now when I plug in my ipod or even put the radio on the volume from the speakers is super low. I have my ipod at max volume and the deck as well and you barely hear it. I have yet to connect the sub because I want to fix this issue first.
edgyteen
11-14-17 05:25 AM
Splunky
10-23-13 01:27 AM
folsep
05-05-10 03:04 PM
lexusnoob
05-29-07 09:02 AM
