VAISTech MediaLinq Plus (ML+) Issue - Randomly Non-responsive
I have a 2007 GS350 AWD with Mark Levinson and a VaisTech ML+ installed.
It has been installed for the past several months now, and generally works great.
Lately, however, it has been a little flaky. I will start the car and the system will not recognize my iPhone, it will not drop into the factory camera mode, nor will it switch to CD/MP3 Emu mode. It will sit at "Waiting for iPod Out" but it won't actually do anything.
I have verified the physical connections and tried fiddling with various combinations of buttons (i.e. switching to FM mode, DVD changer, etc.) but the only way to get things back on track seems to be to completely power off the whole car, thereby depriving the system of power, then starting it up again.
I don't know if I'm running the June or October firmware (I'll check later), but I'm wondering if anyone else has experienced this and has a solution.
I know the VAISTech reps watch this forum. Any ideas, guys?
And just to head off the next response: I realize the car has to have been in reverse at least once per startup for the factory camera option to work. Remember that even if the car has NOT been in reverse, the ML+ system still attempts to bring up the camera view, but will display a black screen under normal circumstances. In my case, when the issue occurs, it does not even respond to the 'factory camera' menu option being pressed. Same goes for CD/MP3 emu mode.
Again, I see no way this can be pinned on my phone(s).
I will check the firmware.
Club Lexus Vendor
I suggest you update the unit first. If this won't make any changes, please contact our customer service via info@vaistech.com to request a replacement cable. Cable you need is the one that goes between Apple component cable and the ML Plus unit.
Thanks,
Thanks,
Thanks,
Thanks,
The cables are fine too, I believe.
Yesterday it was refusing to work, so I tapped the unit like you would tap an old television set when it wasn't working. I heard a click, and it started to work.
Right now I'm suspecting either a bad solder joint on one of the connections, or perhaps some kind of bad relay or something (on account of the click noise it made).
Please actually read this, and let me know what you think.
Thanks!
Club Lexus Vendor
I'm not sure you're reading my posts. I'm running the latest firmware on the ML+.
Thanks!
Thanks!
Please let us know if you need a cable or if you decide to ship it back at info@vaistech.com
Thank you!
I'd much rather try a cable first before shipping out the unit to California at great expense.
I will send the request, but I was frustrated that you weren't reading my message in its entirety.
Moving this conversation to email. Thanks for the response.
It might give out and refuse to work completely one of these days but for now it's working about half the time and I just deal with it.
sparky3
09-05-14 10:07 AM
