what size LCD fits into double din SC400
double din slot in the SC400? I have a 1993.
I was thinking of running the multimedia player out of the trunk, with an in-dash full LCD and visor monitors, etc.
Any suggestions?
TIA
Any suggestions?
TIA
I thought the din was 2.5 not 2.0... Also why not measure it and see what size screen you fit in there? Unless you are doing a flip out, but then you can tell by din sizes.
A 7" wide screen will fit in there just nicely if you fiberglass a face around it. You might be able to do an 8" in it if you take it out of the case and flush mount it under lexan glass.
good luck
good luck
