Installed a ty 140 wiring harness and still no sound any suggestions?
I installed a new ty140 wiring harness and still no sound. Do I have to wire the speakers straight?
It sounds like either your AMPS are not coming on o not getting a signal. 2 ways you can check this. On your outputs use a test light...the light will not be bright at all, but it will come on everytime that channel gets a pulse. Or use a volt meter. I would check to see if your getting power to the amp. Sometimes with aftermarket headunits the amps will only turn on during a certain mode. So check this as well. Make sure the signal coming out of the headunit is staying on at all modes.
dieselpb
10-19-16 10:31 AM
imrat
10-13-08 08:07 AM
