anyone use a jl marine subwoofer in the stock location?
from all my research ive found out that the stock subwoofer in the sc300 is a infinite baffle free air sub. With that said anyone try a subwoofer in the jl marine line to replace thier stock subs with good results? i know the stock sub is an 8 but i will be building a custom bracket im just wondering if the sound quality is any good?
I just hooked my amp and speakers I recently recieved to check if it worked. I should have an update soon as to the modifications needed. It does not fit in the stock sub location, but with a spacer and some cutting it will
i would love to know how to sound as well. People are using the elemental design for the IB sub. Its about 140 and they said it sounds good. I am use the marine sub will sound great too, just a bit less of pounding bass.
Update:
The 10 inch JL marine sub does not fit perfectly in the sub location, but it can be retrofitted to work. The biggest problem is the gas tank when it comes to the mounting depth of the sub and the diameter of the opening of the sub location. The way around that is to use a spacer that is 1 3/4 inch and then ( what i did) was screw it attached from the underside. Sorry I didn't take any pictures during the process, but at least this will answer the questions about JL marine sub fitment.
The way it is mounted is temporary, but it works and it definitely sounds really good. I went from a Kicker L7 sub to this and I wont look back, and I have my entire trunk back! I have to try and see if I can do something custom for the window brake light, or just do with out the light. The only picture I took, was this after it was in. I will take pictures at a later date as everything is going to come back out for dynomat.
As far as the sound is concerned, I still have to seal up the trunk properly to get the best sound out of the sub. As of now its acting like a ported box, which is not the way this type of sub is to be used. I do not want to push the sub until the rest of the project is done, but so far the sound is great!
olddog
10-24-06 08:40 PM
Seminole GS300
16
08-11-02 03:06 PM
