8 OHM sub to 4 OHM AMP
I have one JL Audio 10W1v2-8 sub and a Pioneer GM-5500T amp.
JL Audio 10W1v2-8
10" Single 8 Ohm W1v2 Series Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
Recommended Power Range: 50-300 watts
Pioneer GM-5500T
RMS Power Rating: (14.4V)
4 ohms: 125 watts x 2 chan.
2 ohms: 190 watts x 2 chan.
Bridged, 4 ohms: 400 watts x 1 chan.
Is it possible to hook up this single 8 ohm sub to the amp in 4 ohm bridged mode?
JL Audio 10W1v2-8
Power Handling:
Peak: 600 watts
RMS: 300 watts
Pioneer GM-5500T
I think it should - it just won't produce the 400 watts - probably still more than 200 which should still be plenty. If that works for you (depending upon what else do you have for other channels), all you may have to do is adjust the volume of the amp to match properly with other channels.
So this is what I'm working with:
Rear Speakers - Pioneer TS-A1684R
6-1/2" 4-Way A-Series Coaxial Car Audio Speakers
Power Handling
Peak: 700 watts per pair / 350 watts each
RMS: 100 watts per pair / 50 watts each
Front Speakers - Pioneer TS-A1604C
6-1/2" A Series 2-Way Car Component System
Power Handling:
Peak: 700 watts per pair / 350 watts each side
RMS: 100 watts per pair / 50 watts each side
These are run on a Pioneer GM-6400F 4-Channel Class AB Car Amplifier
RMS Power Rating: 4 ohms: 60 watts x 4 chan.
I've read some other car audio forums and with the help I received here I've gotten rid of the 8 ohm JL Audio sub and bought a JL Audio 10W1v2-4 sub.
10" Single 4 Ohm W1v2 Series Subwoofer
Power Handling:
Peak: 600 watts
RMS: 300 watts
This will be a better fit with the Pioneer GM-5500T Amp. Thanks for the help everyone.
Just waiting for the subwoofer to arrive and them I'm hoping to post pictures when it's all said and done.
On another note, the ebay front speaker adapters suck, waste of money.
Power Handling
Power Handling:
Power Handling:
Peak: 600 watts
RMS: 300 watts
questnyc
05-13-10 10:21 PM
olddog
22
04-24-07 03:53 PM
kokopuffs4
03-08-07 02:56 PM
