98 LS400 aftermarket HU & sub
Old 08-20-12, 06:18 PM
SynicalVip
SynicalVip's Avatar
Default 98 LS400 aftermarket HU & sub
So I just put in a pioneer double din and aftermarket sub/amp. I put in a 2600w planet audio mono block and a kicker L5. Everything is wired correctly and all but the amp overheat so it goes into thermal protection/mode so it shuts off so it won't over heat. So my question is anyone have a way to circulate air through the trunk so it won't be so hot? I know there fans I can get for the amp but would like to know if there some way I can just maybe make room for air to flow through. Thanks in advance for all help!
Old 08-20-12, 08:35 PM
Big Mack
Big Mack's Avatar
Question
Originally Posted by SynicalVip
A 2600w planet audio mono block and a kicker L5.
Need part numbers to be most helpful. If your Kicker is dual 2 ohm coils and you wired them in parallel, that's a big time no no for that amp, IIRC, but shoot the P/N's and we can finger it out.
Big Mack
Old 08-20-12, 09:21 PM
SynicalVip
SynicalVip's Avatar
Planet audio px2600m
Pioneer avic-f900bt
Kicker l5 2ohms everything factory wired in factory box
Big Mack
Old 08-21-12, 10:08 AM
Big Mack
Big Mack's Avatar
Question
What is the P/N? L5 has many iterations. If it's a DVC with 2 ohm coils (which I think it is), it's wired in parallel and that's too low a load for the amp, but need the actual P/N to be sure.
Big Mack
SynicalVip
10-16-12 09:04 AM
Desarae
04-03-11 08:22 AM
GSquicksilver
09-01-05 03:07 AM
lexsc492
03-20-05 04:19 PM
LOTC
16
08-15-01 04:12 PM
Quick Reply: 98 LS400 aftermarket HU & sub
