general question for amp- wire
i been using 8 gauge with a 50 fuse for my MRP 350 amp (700 watt total). I heard people say bigger the better. i been thinking about going knukonceptz 4 gauge for my power wire and ground. will it harm my amp? I also heard the ground wire would be best if it is better than the power wire. any thoughts?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
What people? Bigger can be better if you're at the limits of the wire, but going from 8 ga to 000 ga is a bit of overkill. Moderation, mang.
Speaking of being at the limits, you're at yours. Assuming 100% efficiency that your amp (no amp, really) has, it's 50A @ 14VDC. Since it's closer to 75% efficient, you can add another 13A to that, so 63A at full tilt. You're exceeding the current capacity of that wire - assuming you have 90° C insulation (unlikely). You don't want to upgrade to 4 GA, you need to upgrade to 4 GA.
No. Fuse it properly and you should be fine.
Big Mack
damn i love the break down! the 4 gauge is a bit beefy.there was a chart i found that said if i was doing 400 watt at 16 feet of wire i should go 4 gauge. i think it was 16 feet. I do have a MRP 650 Alpine so i think 4 gauge would be best all around. just hate how the terminal of the amp is so small for the 4 gauge.
Big Mack,
will it harm my amp if the fuse on the power wire is much higher than those on the amp?
Big Mack,
Big Mack
