good source to find oem style radio/decks?
anyone know a good source to find decks like this one? I'm thinking its a jdm one? it would be perfect since my battery is now in the location of the stock cd changer and i can do the aux mod still ![](http://i1161.photobucket.com/albums/q518/2jzinsider/cd_zps23a2ef4d.jpg)
I'm going for a stock style deck to keep the oem look of the interior.
or how about the a aftermarket oem style deck or oem from a another car? anyone have some good ideas?
![](http://i1161.photobucket.com/albums/q518/2jzinsider/VW_INF_2DIN_Mid_RD5_br_1_s_zps7d06fd77.jpg)
I found this one from vw by searching oem style decks but cant find a place to get one or to hook it up.
You won't be able to do that VW one since it turns on by CANBUS. Only way you could do an OEM radio in there is if it was a low level output and then wiring it with a reverse harness(as long as it isn't turned on by data) to the factory harness(since the factory system is amplified). Tbh, an aftermarket radio is going to still be a better solution overall since it's less of a hassle. Or that OEM sc radio in the first picture.
Oh, and you still have to worry about mounting to factory brackets and customizing a trimplate if you tried a different oem radio.
shonufff
ES - 5th Gen (2007-2012)
05-01-17 04:45 AM
