For hardcore SQ guys/gals only...
Moderator - Electronics Forum
Can you believe this?!?!
http://www.aopen.com/products/mb/ax4b-533tube.htm
All the good stuff...no skimping on components either! I wonder if it has any problems with microphonics on the tube - power supplies, hard drives, etc do emit/transmit a good amount of vibration.
Percy
Percy
Looking (and semi drooling) through it right now... MultiCap PPFMX caps get my respect right away! Wonder if I can mod this thing?
Percy
getting more funny ideas...
Percy
Everything in Moderation
Really cool, but...
WATCH OUT!!!
I took a quick look, but I did not see any audio specs on the output of this puppy. (If I missed it, I apologize.) There's a lot of whiz-bang stuff, kitchen sink included, but the trick to this design is keeping all of the digital noise and other artifacts out of the "high-end" analog output. You may find, on closer scrutiny, that this has great functionality, but more noise than you'd like on its output....I never like to see a heavy amount of digital stuff on the same board as the analog output. It really requires the system/board designer to do a pristine job of keeping grounds separated, current loops minimized, etc. If not done right, you wind up with S/N of 80-95 dB, not 100-110+. No matter how much you mod the components, if the power and ground planes and routing of the board are the cause, there's no hope.
WATCH OUT!!!
Erick G
06-20-02 01:44 PM
