Internal parts for Power Antenna?
Does anyone know if the gears inside the power antenna can be purchased separately? The large gear that retracts the antenna cable has worn down to the point that the motor won't kick off. The antenna cable has been replaced twice, once @45K mis and @86K mis.
Thanks,
Thanks,
Super Moderator
i think this time you should just buy a new antenna motor assembly. i had to. it cost a whopping $189 from toyota, the plastic teeth were worn out and therefore the antenna wouldnt go up or down.
