dim control, a/c lights and shift knob lights dont work
Guest
Posts: n/a
dim control, a/c lights and shift **** lights dont work
I've been working on installing a new stereo for a couple days now..
It seemed the lights on the 'P' 'R' ..etc. under the shift **** in the center console, the light behind the red emergency light button, and the dimmer controls(for gauges etc) worked / lit up when I had the new deck in and while the old was in.
I plugged the factory stereo back in, and still the lights didn't work, no dimmer control either. I did a quick glance at the fuses under the e-brake and they all looked fine, but I was using a flashlight and couldn't get a good look without pulling them all out.
I didn't check the fuses under the hood yet. Anyone have any ideas? I'm going to go check the ones under the hood real quick..and take some pics.
i had the same problem to, it is the fuse that is labeled emergency flashers, it was 7.5 amps in my lexus gs400, i dont know what kind you have, but i found the fuse, the emergency lights fuse is what you need, hope this helps
ChuckMcCoy
07-04-15 08:46 AM
