Pioneer AVH-P8400BH(2DIN) Installed in my Lexus ES 350!!!
#61
Not sure what he was using since I never did this project before, but I plan to! Robert_J has this awesome thread about how he did the same install. Here's the link to how he dissambled the radio after you take it out of the car
https://www.clublexus.com/forums/es3...-2007-a-2.html
I would just like to take a peek at the back of my stock HU (the one the OP began this thread with) before I begin any mods.
#62
Iphone 4s tv out function..
Just wanted to show some more functionality of this Piooneer HU.. I must say at this point im really impressed with it..
A new jailbreak was just released for Iphone4/4s. You can get it here!!! http://evasi0n.com/
I would like to say that jailbreaking for iphone is perfectly legal, and if you want at any time you can restore your iphone to the way it was Via itunes..
After the jailbreak process was complete(took 3min), I opened Cydia on my iphone and went into the search function and searched and downloaded DisplayOut.. http://ipad-os.net/displayout-cydia-free/
Its an app that you can only get through Jailbreaking, It mirrors the Iphones screen on an external display(Pioneer HU). If your familiar with the AirPlay function available through AppleTV, DisplayOut does the same thing.. You just need Composite Audio and Video Cables for iphone,http://ca.cellphoneshop.net/av30.htm...FY9AMgod1z0ABg
which you would plug into your Pioneer avh AV in.
#66
When install is complete go into settings on your iphone and make sure Max Screen Resolution is set to 1024x768(VGA/HDMI) in DisplayOut..
Now your iphone is set to mirror any application on your Pioneer Hu...
Navigation!!!!
GARMIN...
Navigation!!!!
GARMIN...
#69
VirtualPool...
And the list goes On! Just remember that you can only control the applications on the iphone screen only, which is fine by me. This method alows you to use way better GPS applications and functions only available on the Iphone!!!!
#73
That plate is bolted on inside the trunk, you will need a 10mm deep socket in order to remove the bolts, 6 bolts and 2 screws have to come out including the licence plate and it should pop out no problem..
As far as camera! i dont want to recommend the camera im using due to 2 issues ive been having.. The first is the light that is attached to the camera does not match up with the OEM licence plate light already on the car.. So what i did was i removed the camera from the light, reinstalled the orginal light and mounted the camera under the orignal light so now both plate lights match once again..
http://www.aliexpress.com/item/Free-...753753432.html
