2008 rx400h ML speaker upgrade Front and Rear door
hi all
I need some help to upgrade ML front and rear door speaker, I have not open the door panel yet, I had been looking around and what I saw was very surprise me. I have 2010 Prius 3 JBL system, the front speaker was 6x9 and rear wa 6 1/2 round, the RX400h and Prius speakers look the same even when I looking for the Front and Rear speaker adapter was the same.
1. How many Ohm for the front and rear for 2008 rx400h ML?
2. What the best speakers should I upgrade to?
3. Where can I get the speaker connector "part #" because I want to save the ML speakers.
This is what I did to upgrade my Prius 3 JBL system
Metra 72-8104 speaker connector
9632cf speaker from Infiniti
6032si speaker from Infiniti
V/r
Khoi Nguyen
V/r
Khoi Nguyen
sizes seem to be the same.. but understand the 6x9 are only used as midbass/subbass no vocals whatsoever..
to find impedance you'll to unplug an meaure across the speaker terminals..
fyi.. JBL, Infinity and Mark Levinson are all part of the Harmon International family of audio..
http://www.metraonline.com/vfg
hi Shibumi1
Thanks for the info, by the way th ML amplifier had 11 speakers, does anybody have any Spec. for this amplifier? I would like to know the watts Max for each output, so I can find the best speaker I can replace them with. any other info would be good like speakers adapter and speaker connector or any direct amplifier replacement without modify would give me more power and did not lose any function.
V/r
Khoi Nguyen
V/r
Khoi Nguyen
peterGX470
GX - 1st Gen (2003-2009)
11-10-05 07:46 PM
