Wiring Question: Aftermarket HU -> GS400
I searched and found some good posts on aftermarket HU installs, including this one:
https://www.clublexus.com/forums/gs-...iy-add-on.html
Do I need TWO of these harness kits in order to avoid splicing any wires?
http://www.crutchfield.com/S-oIqq03I...77#details-tab
If I understand correctly, I need a six-pin and a ten-pin to make all the speaker connections at the factory amp location, and I need an additional connector to get my power/accessory/dimmer/ground immediately behind the factory HU.
Is this correct? Most people seem to splice into the wiring behind the factory HU and I would like to avoid that. Will this kit connect properly in both locations?
Thanks for your help
PS I don't care about keeping the factory sub
Daynja
06-14-07 09:35 AM
Lex*Toy
05-25-07 04:59 PM
