Easiest way to disable original alarm system?
My alarm was fine when I got the car...but now all of a sudden it's been bugging out going crazy for no reason. I pretty much can't lock the doors in my car for more then 30 minutes as the alarm will sound for no apparent reason. I have a 92 SC 400 with a 93 SC 400 engine in it. The other day I had the car at my bosses house to switch vehicles...my alarm went off and he said it was going off all day for about 8 hours straight. I have a switch under my steering wheel to turn it off, but it doesn't seem to do anything. Any tips or tutorials on how to disable it permanently? I plan to buy an after market one in a few months when I get it the car all fixed up and running mint, but until then I'd like to just disable this.
For the record, it didn't start doing this until I reset the ECU on my car... I searched threads but didn't find anything.
oem alarm disarm is a green wire in the drivers side kick panel..ground it once to turn off the alarm.. then after that find the trunk pin wire its red/white/silver dot in the drivers running board an ground it permanently that "should" deactivate the oem alarm.. other than that u can drop the dash an try to locate the oem alarm and unplug it..
I have a problem closing the trunk so the 'latch' clicks shut all the way. When I lock the car, the alarm is 'on' (the red light on the dash is on/flashes, I think). It's fine for awhile, but eventually the alarm goes off when the system realizes the trunk is not properly closed. I haven't timed it so I don't know how long it takes for the alarm to trigger.
Is there some way to remove the wire that controls JUST the trunk lid so when it's 'open' it won't trigger the car alarm? Or do I have to disable the entire alarm system to keep it from going off?
Also, what exactly do you mean by 'ground' the wire? Can you describe how in detail how to do that?
Info appreciated. Thanks.
1st "grounding" means connecting the wire in question to the metal chassis of the car (fyi the entire chassis holds a negative charge)
2nd the driver's running board is the channel under the trim and carpet that runs down the drivers side of the car starting in the kick panel to the rear of the car..it should be very easy to access as the panel is held in by plastic clips..start at one end (using plastic pry or flat head screwdriver using gently increasing pressure to release the panel)
3rd to disable the trunk pin simply cut that wire (separating it from the rest of the alarm) to deactivate the alarm "ground" the side of the wire going towards the front to the chassis and it "should" no longer arm upon locking
Are you sure its red white and silver? Thats a large tight bunch and i havent found t
