Disabling/Bypassing alarm??
Somehow my alarm became engaged recently, and it's been causing my SC to act funny ever since. When things go south there is no juice to anything. I was able to fix it once or twice by using the key to lock and unlock the door. However at other times this fix didn't work at all. Twice it fixed itself just by sitting around for a day or two.
I would like to eliminate the alarm from the picture, is there a fuse I can pull, or a bypass I can rig to take the alarm completely out of the picture?
oem alarm disarm wire is green in the drivers kick panel (it requires a single negative pulse to disarm) as i've told other people after its disarmed locate the trunk pin wire (red wire white stripe with silver dots and ground it permanently) this should shut alarm off...
phrozen
03-25-08 11:35 PM
pimpin gs
01-31-07 09:49 PM
racing fan
20
09-22-03 01:58 PM
