GS 350 ML, replacement?
My ML with nav & dvd headunit keeps shutting off on it's own at varying times. It's becoming more frequent with the hotter weather. I'm out of warranty so a dealer fix is not an option.
Has anyone replaced the ML headunit? Any suggestions? Any problems I'd potentially run into? I've read that the a/c unit is somehow tied into the deck.
I'll prob pull out the rest of the ML system and replace it all with aftermarket, components and amps along with a single din.
http://www.***********.com/automotive/
Unfortunately in this day and age an aftermarket setup would be much more difficult and probably more expensive than just repairing or replacing the stock unit. I don't remember if those have fans anywhere in that setup, the ML amps usually do, and a bad fan would definitely cause the audio to cut out, not sure about the radio controls.
fozzyf
07-05-15 11:37 AM
jtwenger
07-31-12 09:21 AM
