CD Player
CD Player
I have the stock Cd changer. i do not know what is wrong with it. It will play some but, if I go to track 11 it will go to the middle of track 5. it's not those specific tracks that was just an example. I do not know if its the type od cd's i'm using or what. It also takes about 8 seconds to start playing the track i'm on. Do I need to clean it out or what. If so how do I do that.
i have the same issue on my 93 sc400. I have noticed that it only happens with burned CD's. Now mind you it is not all burned CD's only ones that are burned at 16X or higher and using the Disc at once feature. I have noticed if i burn a CD at lower than 16x still using the disc at once feature it will work pretty str8. I beleive it is becase the CD players are older so they have an issue with burned CD's being that CD burning was not that that big in 1992 when these cars came out. Most newer players are able to handle burned CD's alot better. But if anyone has a work around for this i would love to know.
jdm93400
09-01-08 10:18 PM
