What are these wires?
I am in the process of removing the head unit the previous owner installed and came across 2 wires which are not coming from the car's harness.
One is a blue wire that looks like its coming from the driver side. The blue wire is connected to a blue/white wire in the radio harness.
The other is a black wire that seems to lead into the bottom of the dashboard. I am not sure where that leads either. If anyone could give me some advice I thank you in advance!
If the black wire is a ground, where do you think its grounded to? I tried to follow it but it disappears deep in the dash.
Thanks for the reply
blue white from radio harness is amp turn on lead..so the blue wire must be remote turn on to the amp... black maybe a chassis ground it most likely runs to a ring terminal connected to chassis ground.. this is done because some oem ground wires cater to multiple devices so running a separate ground makes better sense as it will eliminate any possible ground loops...
lexus37
09-12-10 08:26 PM
