Insulating foam Vs Expanding foam
they are both expanding but i bought some DAP TEX Insulating foam sealant and is suppose to be using around windows and stuff for insulation. i was wondering if this is good enough for sound deadening and to stop vibration. i have never touched regular expaning foam before so i don't konw if this is too soft. i sprayed some in the trash about 2 hours ago and its still soo soft and foamy type of feeling. its at room temperature. is this too soft to stop vibration?
i just blow dried it for about 1 min right now and it feels soft and squishy. is this good enough to stop vibration or do i need something more solid. i read that regular expanding foam can bend metal. there is no way on earth this can even bend paper.
This won't totally answer you're question, but expanding foam generally takes about 8 hours to cure, so give it a little more time and see how it ends up.
I don't know if the stuff you're trying would work, but you want something that will harden. If you're worried about bending panels, I've heard of a latex expanding foam that won't do it.
Search Function Inc.
Yeah, I have played with Dap Tex before. First of all this thing never gets to solid state. Secondly, it won't sounddeaden any panels since it is way too weak and light to add mass to a metal panel. Thirdly, you do not want to install it on your roof since if something touches or rubs against is, it would start falling off in crumps.
I would use it for getting read of the road noise on the panels that can not be moved (unlike doors). Also make sure you don't lay anything on top of this foam since it would disintegrate. It's a good solution for a select number of spaces.
![](http://www.cureline.net/lex/photos/audio_mat_trunkside4.jpg)
![](http://www.cureline.net/lex/photos/audio_mat_trunkside3.jpg)
Hey Pete, What kind should i use then thats more solid. i sprayed it all into the creaks of my trunk and it seems to help the car a lot. sounds more solid when i knock on the outside. i heard the other types can bend metal. like i said before there is no way this thing can bend metal. maybe i'll go buy a few more cans of the real stuff and overspray it into my trunk door.
There is a lot of stff you can get in home depot. you would need minimum expansion foam. It is easier to keep under controll and it gets rock solid after a day or 2. Just ask around for the foam that gets rock solid end expands the least.
so how do i undo all this. i took out the lining on my trunk door and filled in all the holes. should i just spray more of this other stuff in?? or should i just forget it?
man, just bought some "great stuff" expanding foam from home depot. this stuff is definetly much more solid. the Dap Tex stuff is squishy when its dry. but this "great stuff" is much more solid and hard. i threw it around and it actually bounces its soo hard. the best i can describe the Dap Tex stuff is like cotton.
so pretty much don't buy Dap Tex.
If you are using the regular expanding insulation foam be very careful. If you put too much in and it has no where to escape it will then do what you are talking about bend a body panel. I had a friend that put this stuff in his trunk lid and just filled it and he went in the house and when it expanded it separated the trunk lid into 2 pieces so he had a nice surprise when he came out of the house in the morning. :eek:
