need wiring diagram to install remote start in my 95sc300
I want to install a remote start in my sc but i can not find a t harness so ill wire it direct. i need a write up on how. or at least a diagram and ill create a write up. unless anyone knows where i can get a t harness that would be the way i want to go. thank you for anyhelp
1JZ Single SC400
Check out www.12volt.com. They have all the color codes you need and what does what. Just type on the year and make of your SC. I would highly be against it, due to people running into cars and what not, if left in gear....
That link led me to a bunch of advertisements. not sure where to go beyond that. i clicked links and explored it for a while couldn't find anything.
here's a bit of info for the uninformed.. if u use a DEI brand alarm/remote start (VIPER,PYTHON,CLIFFORD etc) with the current an previous gen brain.. they come with a manual transmission mode. which makes sure the car is in neutral before the remote start option can be used... its the ONLY brand i'll use on a manual transmission vehicle
also.. the python brand (clifford too for that matter) are the EXACT SAME AS THE VIPER the only difference is it says viper on the remote.... python is on average $50-$75 cheaper than the viper so save some money an get the same protection....
http://www.viper.com/ShopViperProduc...tegoryCode=104
http://www.pythoncarsecurity.com/pro...?ProductID=633
linus73
12-28-12 11:45 AM
