MS8 - ML install ?
MS8 - ML install ?
Morning. I have had my JBL MS8 for 2 or 3 years now - whenever they came out I picked one up to integrate my aftermarket stereo into my 3GS that is ML equipped. Everything is installed and currently run by an Audiocontrol LC7, which we will be swapping out. Just been lazy I guess, since this should be a fairly easy swap; been sitting on the JBL for too long and need to get it in.
I just wanted to see if anyone had installed the MS8 into a ML equipped car, and if so, what should I complications should I be prepared for? Thanks for any help that can be offered.
a word.. sell the MS8... they have never worked properly.. ALL the 1's i've installed(20 or 30) have come back with problems and had to be swapped out and or finally replaced... and to boot the ML system is a difficult enough unit to deal w/if the LC7 works fine LEAVE IT ALONE......
I have no problems with navigation or Bluetooth calls, below is my post with install information..
https://www.clublexus.com/forums/gs-...gram-help.html
