Gs Amp.
Gs Amp.
PULL THE AMP AND CHECK TO SEE IF ITS WATER DAMAGED . IT WILL SMELL BURNT. CHEAPEST IS BUY A USED WORKING AMP. THE PART AND PIONEER MODEL NUMBER IS ON THE AMP.CORRECT THE WATER PROBLEM OR THE REPLACEMENMT WILL BURN UP THE NEXT DAMP WEATHER. THE DRAINAGE TUBE COULD BE PLUGGED OR THE TRUNK LIP MOULDING LEAKING.
lexusaudio,
TWO things here, first of all, you need to use the reply button, and not the new thread button when you respond.
Second, you need to kill the caps lock.
Thanks
MW
Thanks
MW
ki_soarer
14
10-26-05 11:22 AM
moemoe_xp
12-30-03 11:43 AM
