Installing Alpine CVA-1003
OK.....How do I connect the foot brake and parking brake wires to their respective sources....I can install a radio but this is the first time I install a screen. anyway the manual said one wire will be connected to a ground side of an indicator and one to the parking brakes indicator power...so technically shouldn't it work if I ground the one that needs to be grounded and I attach a 12V source to the one that needs the power???
By any chance is there someone that knows the colors of the wires I need to use to do it "legally."
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
and by "legally" I mean doing it the correct way and not using the "black box" or any bypass for the video lock. My car (as do most cars) has an inactive zone in the parking brake where the indicator light will be on but the brake won't yet be applyed....so i dont have a problem doing it the right way.
sounds like your trying to drive while watching dvd's. i would just grab those bypasses on e-bay. even though when the breaks are applied to the first notch it doesn't seem like the breaks are engaged, but really they are. and its not a good idea to do that bro. i would avoid that if you can.
Registered User
you can power up the foot brake wire but you can't simply ground the hand brake wire because alpine requires a "fancy dance" before video is enabled. specifically, alpine requires you depress and hold the foot brake while you pump the hand brake 3 times before you can let go of the foot brake. so it will be better if you hook up the parking brake wire to a switch that is grounded on the other end.
or buy this and you are set every time you start the car...
![](http://www.go2pac.com/products/images/TR-7.jpg)
Registered User
alpine uses 2 safeties...a wire connecting to the hand brake and another to the foot brake. when the handle brake is on, it sees GROUND. when you press the foot brake, it sees POWER. so if you think about it, you can wire those 2 safety wires to switches that are appropriately connected to either ground or power. i had the 1005 in an accord, and i ran the foot brake safety wire to the actual foot brake but i ran the hand brake wire to a switch (which was grounded). to enable video, i depressed and held the foot brake while i flipped the hand brake switch several times back and forth...when i released the foot brake, i got video. now if you do not prefer to wire up the foot brake safety wire to the actual foot brake, you can wire it to another switch which is then wired to power. you basically flip this switch, flip the other one several times back and forth, and then finally flip the foot brake switch back and you get video.
do you see what i am saying or are you even more confused?!?!?
jucee187
Suspension and Brakes
08-12-04 10:08 PM
