Last edit by: IB Advertising
Browse all: Interior
- IS: How to Install Vaistech iPhone/Android Integration
Step by step instructions for do-it-yourself repairs
Vaistech iVic-i Review (Touching iVic-d too)
Integration of smartphones with car infotainment system is getting pretty fancy these days. Over the years Vaistech has come up with different innovation solutions, from satellite to iPod and most recently with Apple and Android systems.
This is a review of their latest iVic-i Apple iOS integration system, available for 5th and 6th generation navigation system. The Vaistech iVic-i is basically replaces the discontinued ML+ system and by any means, this is quite a big update.
Product Content
The unit with all the harnesses
Since these are literally like mini computers, the iVic-i brain is not small. It measures around 6x4x1.5. The package comes with the plug and play radio harness and blue digital video cable. To ensure solid installation, Vaistech also includes bracket and zip-ties so you can secure the cable with the unit, from my experience this is especially helpful when you try to conceal the unit in tight space. Because of the extensive instruction manual, Vaistech has switched to CD instead of printed copies but you can view them on their website too.
The unit is of very high quality just like the rest of their lineup, the unit is very sturdy and in the manual it states clearly what each connector is for and also what area to keep clear (heat sink).
What’s not included with the package is the Apple digital video lighting cable, Apple lightning charging cable, and regular HDMI cable. You will need to purchase those separately.
Installation
To install the iVic-i, you will need to access the back of the radio unit (the radio harness) as well as the navigation screen unit (digital video connector). I am pretty experienced with this already so it didn’t take me long, but it also depends on vehicle and how comfortable you are working on cars.
The overall installation is very straight forward and noticeably simpler than the ML+ (fewer cables). You will need to program the unit according to your vehicle, but it’s just one time setup so it’s not a big deal.
iVic-i modes of operation
Mode menu setup
Simplified / customized mode selection
Once the unit is recognized and you see the startup / setup screen, you will need to connect your iPhone to the iVic-i through BT, crucial for control purposes. Moreover, you will need to go to Apple app store and download the Vaistech iVic app as well (free).
iVic app
Integration / Functions
Once everything is setup correctly, you can now enjoy this amazing unit. With the iVic app running, the screen displays the music player, which is a more fine-tuned version of the one in ML+. ML+ always suffered in terms of control where you could only use the controls on the right hand side, but with the iVic-i, now you can touch the buttons directly, making it very intuitive to jump between playlists, artists, songs, and albums. Graphic is also a lot more refined than that in the ML+ with a more modern look.
Music player, able to display foreign language
Music player is only a small part of the iVic-i suite. With a touch on the screen, another screen pops up and now you have access to 4 other features: contacts, calendar, weather, and maps.
App menu
You won’t have to transfer your contacts from the phone to the factory navigation system, iVic-i directly accesses that on the phone and displays all the details on the screen. Calendar mirrors all the details you have on your phone for quick access.
Phone contacts
Calendar app
Weather app is very clear and I particular like all the graphics. The map function is somewhat redundant (considering most cars already have factory navigation), but it’s still very nice nonetheless.
Map app
I don’t have particular Internet radio app on my phone, but if you do, the system also allows you to steam radio. There might be some limitations on text displays and controls, but the integration is there.
Video playback from your iPhone is a bit tricky though, you can’t do it in the APP mode and have to switch over to the HDMI mode, which is basically mirroring your iPhone. You will then have to go to your iPhone and start the video playback and the video will display full-screen. The video quality is very good since it is all digital. I talked to Vaistech about integrating video playback into the iVic app, it’s probably on the wishlist.
Video playback
Of course, while plugged in, the system will charge the iPhone as well. Keep in mind that with the iVic app running on the phone, the screen will be dimmed but not shut off and that is by design. And if for any reason you need to access the rest of your phone, as soon as the iVic goes into background, iOS disallows feeding and the navigation screen will go to “start your app” icon.
From my experience, the iVic-i is also more stable. With the previous setup, connecting and disconnecting the phones when the system running could sometimes yield undesirable results, but so far with all the testing I have done, the system performs very solidly.
Verdict
The Vaistech ML+ was a major breakthrough when it came to full graphical system integration. However I always felt that the setup was not complete, partly due to the relatively basic interface graphic and most importantly the limited controls.
But with the latest iVic-i, it’s such a different unit and a step up in every way. It’s easier to install, more solid, better graphics, and together with the iVic app the controls become very intuitive now.
And let’s not forget the price. At $400, this is $100 cheaper than the ML+. Together with the other cables you need, you are probably looking at around $460 plus installation. In my opinion, if you have 5th and 6th generation navigation system and have no or even basic integration system, the iVic-i is totally worth it. If you already have the ML+, the iVic-i is still a very nice update though it becomes a tougher call.
Installation Tips
- pay attention to the digital video cable, you cannot pinch or bend the wire too much
- take advantage of the included bracket to tie down the digital video and HDMI cable. This avoids the cables from getting loose and prevents the video / graphics from having issues
- test your system once all the cables in place and brain located to make sure there is no noise in graphics
- iPhone 4S will work on iVic-i, however it’s slow and also has some other limitation. Recommended to have at least the iPhone 5
- to make programming the unit easier, turn on the beeping function on your navigation, otherwise you might not know if the unit is programmed correctly or not
- before connecting the radio harness, make sure both dip switches for programming is on the DOWN position. Once connected, set them according to instruction
Operation Tips
- If you want adjust the treble and base in iVic mode, choose MP3 emulation as the source, do your adjustment, and then press and hold SCAN until it goes back to graphical mode
- if you start the car with iPhone plugged in but the iVic app NOT running, the system will still pick up from where it left off last time and continue the song playback. The screen will just show “start the app” icon. This is convenient if you only care about songs playing without details on screen
Related iVic-d Installation Tips
- setup is a bit more complicated because you need to setup the screen and cursor position (unless your phone is already on the preset list)
- be very careful on choosing the MHL adapter, you want to make sure you get one that works perfectly for your phone, otherwise you can be debugging a few problems at the same time
Product Content
Installation
Mode menu setup
iVic app
App menu
Phone contacts
Calendar app
Map app
Video playback
Verdict
Installation Tips
Operation Tips
on the gx470 i mounted it below the passenger seat behind the nav unit
the gs350 is trickier, there isn't any straight forward good spot that i know of. what i do is behind the carpet on passenger seat foot well up close to the bottom of glove box. there are foam, i cut out an area for the unit to rest on
I have the ivic for Android, I think it's the same size as the ivic-i. I mounted my unit under the glove box, right above the plastic cover.
I got it yesterday and was excited about putting it in. After I took the center console out I was like, damn, there is no room under here. I'm going to try what you guys suggested and if all else fails I'll take it to shop and let them figure it out!
I guess I will be going to my local shop this week!
