10" subwoofer in 8" hole?
Old 04-28-14 | 06:58 PM
Br4den's Avatar
Br4den
Default 10" subwoofer in 8" hole?
My Soarer never came with a subwoofer, just has the blanking plate with the X on it. I measured it and its 8" in diameter. Does that mean I can't fit a 10" sub?
Old 04-28-14 | 07:21 PM
Studiogeek's Avatar
Studiogeek
Thumbs up
I don't know anything about the plate because my car came with a 10 inch sub already installed. If you are willing to modify the deck you can obviously fit a larger diameter sub in. I think the depth is generally the issue because of the gas tank. If you can find a big sub that is shallow enough, you should be good. :thumb up:
I'm no audio installer so hopefully others will chime in.
Old 04-28-14 | 08:30 PM
SCereal's Avatar
SCereal
A dremel, an mdf ring and a shallow mount free air sub means your possibilities are vast.
Old 04-28-14 | 09:32 PM
Br4den's Avatar
Br4den
This is what it looks like. If the deck was flat it would be no problem to cut a bigger hole, but that area is raised
Old 04-28-14 | 10:08 PM
Br4den's Avatar
Br4den
I think the reason I'm confused and made this thread is because of this post
Originally Posted by BradHoff
i have a 95 sc400 with the pioneer system and my stock subwoofer is 8inch. im in the process of replacing it with a 500watt JL audio 10w3v3-2 and it fits perfectly in the opening...except for it hitting the gas tank. Im doing what others did and re-using the black O-ring but it still needs to be put up another inch. Also i was at a buds sound shop and they recommended making a box around the gas tank and filling it with poly because it is free air. Im up for the challange and ill see if the box really helps.
How did his 10" sub fit perfectly when his stock sub was 8"?
Old 04-28-14 | 10:23 PM
SCereal's Avatar
SCereal
The listed cutout size required for that JL sub is 9" so unless the soarer and sc are different in cut out size I don't see how it would if you measured 8" diameter cutout. If you can't modify the opening gonna be stuck with finding a sub with an 8" mount hole. I could have sworn mine was 10" but it's been years since I ripped my stock stuff out and I just covered the whole. That does make me remember there was a plastic trim rim ring of sorts that was fairly tall. I remember cutting it up to make a better seal. Might have had provisions to get a larger sub mounted in it. Maybe someone has their interior out and can snap a pic.
Old 05-11-14 | 07:41 AM
ocr's Avatar
ocr
I have a 90 LS400 and it came with an 8" sub stock. It has been blown since I bought the car in 2011. I'm going to install a 10" JL audio sub in its place. I am going to try just taking a 10" MDF ring to space it up an inch and size it up to 10".
subzero32
02-07-13 10:52 AM
t70 supra
02-26-09 05:51 PM
One HoT
11-09-05 09:18 PM
iNdoMeX
06-24-02 10:21 AM
Sexlexo69
SC- 1st Gen (1992-2000)
14
01-09-02 06:19 PM
