Backup camera on 04 ES330 w/navi
Hi
I'm looking to add a backup camera to my 04 ES330 and display on my OEM navi
Question is hookups on back of navi. Understand separate 4 pin jack is 12v, ground, video +/-
Need to verify trans reverse signal to navi, and where do I locate the 4 pin connector.
Any wiring or DIY help would be aprechated
Also, is there any difference between the 04 to 05 system ?
Well sure you can put a backup camera on the vehicle. You mentioned it had a OEM NAVI therefore all it needs is a vides course and need to verify you have a reverse signal going to the navi.
Connections
White 4 pin connector Next to the blue connector Looking right to left
1) +12v
2) V+
3) -12 ground
4) V rtn
Poke around in the gray connector, should be a reverse signal. Not sure of type of sig "hot, ground"
Good luck, maybe someone else can join in with some additional information
Connections
1) +12v
2) V+
3) -12 ground
4) V rtn
