Need help: 99 ES300 Stero Install
Old 09-09-14, 01:58 PM
needsinfo
needsinfo's Avatar
Default Need help: 99 ES300 Stero Install
As the title says i need help with a stereo install for a 99 ES300.
Backstory:
I bought a new stero for my firend's birthday and want to surprise him with it installed because his does not work. I do not own the car and want to make it as easy as possible for myself when i go install it on Friday.
What i bought:
Kenwood KDC-BT318U
http://www.sonicelectronix.com/item_...DC-BT318U.html
Metra 71-8112
Amazon.com : Metra 71-8112 15-Pin Reverse Factory Radio Harness for Select 1992-1999 Toyota/Lexus Vehicles : Vehicle Wiring Harnesses : Car Electronics Amazon.com : Metra 71-8112 15-Pin Reverse Factory Radio Harness for Select 1992-1999 Toyota/Lexus Vehicles : Vehicle Wiring Harnesses : Car Electronics
Metra 71-8112 amp integration?
Amazon.com : Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin : Vehicle Wiring Harnesses : Car Electronics Amazon.com : Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin : Vehicle Wiring Harnesses : Car Electronics
Scosche LS2081B / LS2081( install kit)
http://www.sonicelectronix.com/item_...1B-LS2081.html
Questions:
1. Do all 99 ES300 have a factory amp? or is it just an upgrade? This is why i bought both wire harness.
2. If it does have a factory amp, do i need to bypass with and splicing or is the Metra 71-8112 amp integration enough?
3. On the wire harness,metra 71-8112, without the amp integration, there are only (+) speaker wires, but on the back of the unit there are both (+)(-) speakers wires. Will the unit work with just the (+) connected. Here's a diagram of the Metra 71-8112: http://www.metraonline.com/files/pro...NST71-8112.pdf
Any information would be helpful. Thank you.
Old 09-10-14, 11:51 AM
needsinfo
needsinfo's Avatar
Bump. I look at other thread but most of the 99 es300 stereo install has lost all thier pictures
Old 01-19-15, 04:12 AM
Stompkin
Stompkin's Avatar
Did you ever get your receiver installed? I'm tackling a similar project this coming weekend. Would love to know how yours turned out.
needsinfo
09-10-14 11:40 AM
lexuss01
11-26-09 04:44 PM
Quick Reply: Need help: 99 ES300 Stero Install
