92 ES300 CD Changer Question/help...
The other day I was disconnecting my CD changer because it was broken and I was going to have a friend take a look at it...So I disconnected it and now, all of a sudden the radio doesn't work...
Did the anti-theft come on and shut the radio down because I disconnected the cd changer?
Is there something I can check in the area that I might have hit?
If I put in a new deck, will I run into problems with the install because of the anit-theft problem (if that is the problem)?
I mean basically I had disconnected the two sets of wires connecting the changer before and this didn't happen.....Any thoughts?
THE ANTI THEFT SYSTEM WAS OWNER INSTALLED ON THE LEXUS STEREO SYSTEMS . IT WOULD SAY CODE IF IT NEEDED A CODE. IF RADIO HAS NO POWER AND FUSES WORK THEN YOU MUST HAVE BLOWN THE OUTPUTS WHEN YOU DISCONNCTED IT. OUCH IF THATS WHAT HAPPENED. THE EQUIPMENT IS 13 YEARS OLD AND TODAYS STUFF LUCKY TO LAST A YEAR OR 2. YOU CAN GET WORKING USED HEADUNITS AND CHANGERS FOR CHEAPER THAN FIXING...................................................................................................................................................................................... I GUESS DISCONNCTING BATTERY THE ONLY SAFE WAY TO DISCONNCT ANY OF THE AUDIO UNITS.
Originally posted by caladuke
no one knows why this doesn't work? any suggestions? The fuses are all ok....
Tom
what are outputs? Do you mean the head unit? Why is that an ouch? Can I just replace the headunit with a deck from BestBuy or something?
also thank you both for your suggestions...working on the end caps Tom...
