Hearing Loss and Audio Upgrades
It's a fact, as we age our hearing degrades. Add in damage from loud noises and it can happen at an even younger age. Generally, it's the high frequencies that are the first to go. What that means is you can still hear them if you are able to "turn up the volume" to your tweeters without increasing the volume of midrange or bass. That's where a quality equalizer will make a big difference. Having good tweeters is also important. This make seem obvious, but if you're not happy with your car audio, first adjust the treble level all the way up. Or if you have an equalizer, a general guide is to start boosting at around 12 khz adding more boost for each step above 12 khz, giving the most to the 18-20 khz level. You may find that your stock system sounds much better and thoughts of new speakers and amps simply fade away. I'm not trying to talk anyone out of the pleasure of upgrading your system. Just try this simple adjustment first. Then, if you decide to upgrade, keep in mind the higher frequencies as they relate to your age and potential hearing loss. There are some websites available to help quantify your hearing abilities as they relate to frequencies. A good set of headphones is essential for best results. In this age of big bass, it's easy to overlook the tiny tweeter's importance. Just my two cents based on research and MHO.
With the amount of bass that I have "endured" over the years (self-inflected, I admit), it is a wonder I can hear at all. I do still have a keen ear though and use Hertz Mille tweets, so I'm good. Lol.
rkw77080
12-08-20 06:31 AM
lowKut
05-30-08 10:08 AM
Hameed
01-07-04 10:28 AM
