lexus head unit with aftermarket amp
Old 06-23-15, 05:30 PM
LEXZILLA
LEXZILLA's Avatar
Default lexus head unit with aftermarket amp
i own a 03 sc430
i want to keed the original head unit and add a aftermarket amplifier and speakers to it !
can this be done?
thanks in advance
Old 06-26-15, 09:59 AM
LexRuger
LexRuger's Avatar
Yes. You'd want to get a channel summing device or a sound processor like the JL Cleansweap to make it sound good.
Old 06-27-15, 07:30 PM
Slammer1
Slammer1's Avatar
There are quite a few "OE Integration" devices on the market to achieve what you are trying to do. Search YouTube for what you are looking for, as well as Hi-Lo converter. You will need a device that will take high level (speaker wire outputs) and convert them to RCA/Interconnect connections for the amplifier that you are adding. As mentioned by the previous member, a signal summing device such as the CleanSweep by JL, the 16-6ix my Memphis or a 360 by Rockford Fosgate would give you a full spectrum to send to your amp(s). If you only want to add a subwoofer amp, you could simply wire tap the signal to the factory sub with a hi/lo converter and use it. Been done many, many times before. Just gotta read up on it and decide which way you wanna go.
Old 07-30-15, 02:44 PM
blake2016
blake2016's Avatar
Default Need help! 2000 gs300 stereo
I installed an Alpine CDE-W235BT in my car and when I had it installed, BBY had to bypsas the factory amplifier. I was wondering why they had to bypass it and if there is any way I could wire it to the radio to give it power bc without the amp there is no sub.
Olsencar
08-24-21 02:35 AM
jbickhard
02-14-19 12:34 PM
LEXZILLA
06-26-15 08:14 PM
Skorpos
05-02-14 10:15 AM
CVBigRig
03-16-14 05:43 PM
Quick Reply: lexus head unit with aftermarket amp
