2008 RX350 door speaker help requested
Has anyone installed an 8-inch midrange driver in the front door of a 2008 RX350 - to replace the OEM 6x9 - without needing more than a wood mounting plate.
I am looking at the Rockford Fosgate PPS4-8, 4 Ohm, 8-inch midrange driver. The mounting depth is 2-15/16, but with a wood mounting plate, I do not think that depth clearance will be an issue. A previous post showed 2-1/2 inches of depth available on a 2008 RX350 with the window down.
If it needs more work than just a mounting plate, I would probably lean towards the 6-inch version.
