12W7 in Rear Deck, Yes or No?
#31
I'm doing a 10W7 into the back deck opening as well. I will post my results. Hope it turns out okay. I'm not looking for much output. Anything will be better than the stock unit.
#32
Re: Same
Originally posted by angelslex
P.S Can you still get to your spare and how did u do the sides of the boxes .if Im looking at your box from the front the middle is just the sub box and the sides are just wood correct? and what did you do with rattling on top of the deck?
#33
#35
Guru,
250 would be the minimum power you would want to run for a 10W7.
Below is the link to the JL site with ratings on their subs.
http://jlaudio.com/subwoofers/RP_Chart.html
I'm currently running a 12W7 with the 1000/1 amp.
Chris
Chris
#37
hi screwface,
i'll try to find the pics I took. its actually mounted in a box, firing up into the hole. (I know many people may not like that) I have styrofoam surrounding the sub to help port the air through the hole. Between the sub and the deck is about 3-4 inches. (Since the sub has a 3in excursion). Once I find the pics I'll post them, or just re-take photos.
Chris
Chris
#42
Thanks sld. Actually it is mounted in a box under the deck. The rear deck would not be able to support the weight or movement of the 12W7. The box is actually 1.5 inches thick
sup tturbopimp,
the sub sounds really good, thanks to a piece of thick foam channeling the sound through the factory whole. Without that I don't think it would the sound would reproduce correctly. .
Chris
sup tturbopimp,
Chris
#43
nice read
i have two 10w7' firing from my rear deck, and i must say it is loud as s$#t. I had the entire rear deck lid redone and rebuilt. The box is built onto the amp box in the rear of my trunk, its very clean and simple. I have the two 500/1's on the two subs and a 300/2 on the jl xr components. Head unit has the rear door speakers for surround sound when movies are going. But i love the sound, just going with more dynomat soon. Any questions? just ask
#44
Lightwave76, that is a very tight and clean setup, I was thinking of doing something similar.
Few questions though:
1. Did you do anything to combat rattling and vibrations?
2. Are you using MB seperates or Coax's?
3. How many DB's do you think you're hitting?
4. And, do you think you could of squeezed in a 13W7?
Thanks.
Thanks.
