Will 19/275/40s +40 fit up front???????
Will a 275/40 +40 19x9.5 fit fine all the way around with no problem? I know it'll fit in the back no problem but whats it like for the front? No one seems to know the answer and I've been searching all through the tire fitment thread
Steve K.
You want a tire height between 25.5-26 inches. The new Mustang has huge wheel arches and from the factory comes with a 28 inch tall tire combo. The SC does not. They won't fit.
Steve
Steve
so the side wall is essentially to tall/wide ? Id have to go with a 30mm instead of 40. Thanks for the response!!
30 is the aspect ratio. 275 * 40% = 110mm * 2 = 220mm/25mm (1 inch)= 8.8 inches of sidewall plus 19 inches for the wheels = 27.8 inches. A 275/30/19 would be optimal.
Steve K.
Steve K.
