Anyone looking for a custom trunk build up?
I just wanted to throw this out there and see if anyone is looking for a custom set up for their trunks. Im thinking about changing mine around a little bit, depending on if I can recoupe some of the cash I have into the build up. I would be selling the box(with or without the JL12W6V2), and the side amp racks(no amps, just the build up. The set up has a box in the back with a 12" jl firing towards the rear, with an amp rack built into it. It also has amp rackzs built on both sides of the trunk. I have JL amps in there now, but im sure you can fit other amps in there as well. Here are a few pics. Im thinking of going with 2 10's, adding another JL 500/1, and flushing all 4 amps in the floor.
https://www.clublexus.com/gallery/sh...t=1&thecat=998
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
i like the stealth look with the covers, you thought about putting the subs in the rear deck, it sounds real good in the car, i need to post pics. as soon as i can i will. i have three amp and the box where your sub and amp is. nice setup? you use alot of dynomat?
Thanks for the compliments. Im pretty happy with the results of the sub firing to the rear of the car, plenty of bass. Im just looking to switch things around a little. I had the sides built for the amp racks looking to save trunk space and keep the access to the spare. Now Im looking to get a little more room width wise, I cant fit my clubs in the trunk the way it is now. I have always liked the amps in the floor look, but I will lose about 3 inches or so of depth if I keep the spare, which I will.
By the way, I didnt use any dynamat, and I dont have any significant rattling issues.
It looks nice, I might be interested in the main box & woofer since I have the same amp and it's cut for it already. Please e-mail me ( chris@everydetail.info ) the details on the box construction & specs as well as any pics you might have of it before it was installed or built into the car.
Did you modify any of the trunk to get this to fit? Besides removing the stock sub that is.
Thanks
Thanks
Yeah, Stealther is right, Im thinking about adding another 500/1, I would be keeping all of the amps. Stealther, you would almost need the side pieces to make it look right. The box itself has an edge on each side that meet s up with the side amp racks. If the sides are not on there and the box is by itself, you would have a gap on both side. Take another look at the pics and see if you know what I mean after my half a*s description.
