Compass Mirror Upgrade
Originally posted by j2tha0e
looks great bro...
did you already have a self dimming mirror?
looks great bro...
I've been getting PMs for pictures, it's pretty straightforward and took only 10-15min including calibration time. I did snap some pictures ( 512mb memory card in the camera, I take pics of everything ) that I'll post later this evening or tomorrow.
Its the little things that make me happy!
Here are the pics!
Here it is, before the install, front view
Here is the rear
First you have to pull off the garage door opener panel - this was done with a thin flatblade screwdriver
Remove these two screws from inside the garage door opener panel
Next remove the clear plastic cover for the dome/map lights - used same screwdriver
Here is a look at the New Compass Mirror (A) and the Old automatic dim mirror (B). Looks to be electrical tape on the new mirror's harness but I didn't check it since I was in a rush
I didn't get pictures of it, but you need to pop the plastic cover off the top of the mirror (where it touches the headliner). Inside that cover there is a screw that you need to remove, this holds it to the glass-mount.
Next pull down on the front part of the lamp assembly and slide it forward, this exposes the mirror plug (A) and the hole you should feed it through (B).
That's it, reverse the process and follow the instructions on calibrating your new mirror!
Here is the rear
WhatYaGot
06-10-08 10:49 AM
