help me find/make a mirror tap..
Old 10-06-16, 12:02 PM
joedaddy1
joedaddy1's Avatar
Talking help me find/make a mirror tap..
trying to see how I can get needle and butt crimp in one piece (i'll buy the usb converter separately. I am trying to create a power source for a dash cam by tapping into the power mirror OEM plug/harness.
I am essentially trying to re-invent this, since it is not available anymore.:
I wouldn't mind paying $20 for it.
https://amzn.com/B01AYS4JZ4
Old 10-06-16, 01:02 PM
NJToany
NJToany's Avatar
What dashcam are you installing? I Just finished my dashcam and radar install. All I used was "add a circuit" which i tapped to the ACC fuse.
Old 10-06-16, 02:11 PM
Ratchey
Ratchey's Avatar
This isn't exactly what you are looking for but it will work. Instead of going into the back of the plug, this just taps the wire with a needle and the cap secures it. You can't even tell the wire had been pierced when removed. I used these for my backup sensing wire for the rear view camera in my 4Runner. Will be using them to add a camera and detector to the Lexus.
http://www.ebay.com/itm/10-Pack-RED-Posi-Tap-20-22-ga-wire-in-line-connector-small-slick-quick-easy-/261091011966
http://www.posi-products.com/posiplug.html
joedaddy1 (11-18-17)
Old 10-06-16, 02:15 PM
joedaddy1
joedaddy1's Avatar
I haven't decided yet.. probably a Falcon 170
hmmmm... okay.. not my first choice.. but looks like it'll get the job done.. thanks!
Old 10-06-16, 02:18 PM
Ratchey
Ratchey's Avatar
The other thing you can do is just tin the wires. Add heat to the wire from a soldering wire and then touch the solder to the wire. It will pull the solder in and make the wire very stiff. You can then just push that into the harness.
Old 10-06-16, 02:19 PM
joedaddy1
joedaddy1's Avatar
The other thing you can do is just tin the wires. Add heat from a soldering wire and then touch the solder to the wire. It will pull the solder in and make the wire very stiff. You can then just push that into the harness.
yea... as you can tell i have almost zero wiring skills.. and negative soldering skills
Old 10-14-16, 11:49 PM
stevex48
stevex48's Avatar
am also just like you
Badasilva1
08-16-16 12:42 PM
FishBike
09-14-14 03:10 AM
mac12
RX - 3rd Gen (2010-2015)
50
06-27-14 05:37 AM
squarehat
07-10-02 11:57 AM
Quick Reply: help me find/make a mirror tap..
