Frequency Response Output - 4th Gen GS 350 Mark Levinson
Does anyone know if the front door woofers in a 2014 GS 350 w/ Mark Levinson receive frequency all the way down to 20Hz, or do those front door speakers receive a high-passed signal? Looking to combine the front left & right dash and door speaker-level outputs through a MiniDSP C-DSP 6X8 (which only has 4 channels of speaker-level inputs), combine the signals in the MiniDSP, then output line level separately for a dash tweeter, door speaker, and a subwoofer. However, if the front door speakers are high-passed, I will have to use a separate unit, such as an Audio Control LC7i to combine the door woofers with the subwoofer PRIOR to entering MiniDSP. Thanks.
Ultimately, what I am trying to achieve is to replace the front door left/right speakers with an aftermarket woofer, replace thefront dash left/right speakers with an aftermarket tweeter, add an amp to power both, add an amp to power an aftermarket subwoofer, and add DSP control, such as the miniDSP C-DSP 6X8. That miniDSP is limited to 2 pairs of line level inputs - if it had three, I would simply connect the ML front dash, front door, and rear deck woofer and my problem would be solved. It is a given that the speaker level signal for both the front dash and front door left/right speaker pairs be included into the signal into the miniDSP C-DSP 6X8. What I'm not certain, and the reason for the question, is whether or not I needed to sum the front door ML woofer speaker level signal with the rear deck ML sub speaker level signal to get the full 20Hz spectrum.
I just wanted to make sure the miniDSP is fed a full-spectrum (20Hz-20kHz) signal. If that means combining the ML sub speaker level signal WITH the front door woofer speaker level signal, so be it - it just means that I would have to incorporate another piece of equipment to my install (more expense, another point of failure, another piece adding noise, etc). Thanks.
Iparkcars
04-02-18 12:34 PM
